mgrzywacz
Oct 21, 2012Aspirant
Duo v1 expansion: 2x 750GB to 2x 2TB - But Volume Not Larger
I had 2x 750GB Samsung disk's in my Duo v1. One disk recently failed, so I decided to upgrade to upgrade both disks to 2x SeagateBarracuda ST2000DM001 disks (they are on the HCL for the Duo). Fist ...
Oct 23, 2012Guru - Experienced User
The online boot menu FAQ is not as clear as the hardware manual on the flash pattern.
Hopefully the reset will solve your problem!
