Tournifreak
Jan 24, 2014Aspirant
Duo v1 with corrupt root after firmware "upgrade"
I rebooted my Duo v1 via Frontview to upgrade to firmware v4.1.13 Since the reboot, it doesnt work. I have all the lights on the front of the ReadyNAS flashing 3 fast flashes, followed by 3 slow one...
Jan 24, 2014Guru - Experienced User
You can try installing linux reader on a PC (http://www.diskinternals.com/linux-reader/). Then connect disk 1 of the duo to the PC, using either the SATA or a SATA->USB adapter. That might allow you to pull your CD images off.
