Tournifreak
Jan 24, 2014Aspirant
Duo v1 with corrupt root after firmware "upgrade"
I rebooted my Duo v1 via Frontview to upgrade to firmware v4.1.13 Since the reboot, it doesnt work. I have all the lights on the front of the ReadyNAS flashing 3 fast flashes, followed by 3 slow one...
mdgm-ntgr
May 06, 2014NETGEAR Employee Retired
Did you follow the boot menu procedure in the Hardware Manual?
Also did you check my explanation on rnasguide.com to check which Duo you have?
