Migroo
Jun 05, 2012Aspirant
Duo v2 - Can't add second disc
Hi guys. Can someone help? I'm trying to add a second disc to my x-raid volume. This is the second time I've tried. The first was with my original in slot 1. That failed, so I tried turning the NAS...
evan2
Nov 14, 2012NETGEAR Expert
smartctl can not open the disk, could you use WD tool (Western Digital Data LifeGuard Diagnostics - DLGDIAG for Windows
) in Whindows to write zeros? then do quick test using the tool, if it is OK, hot insert to Duo v2.
You had better not use WD Green disk do RAID, because WD officially doesn't support RAID user cases in more than 2-bay device for WD Green disk.
***** Disk SMART log for channel 2 [sdb] *****
smartctl 5.42 2011-10-20 r3458 [armv5tel-linux-2.6.31.8.duov2] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
Smartctl open device: /dev/sdb failed: No such device or address
