Migroo
Jun 05, 2012Aspirant
Duo v2 - Can't add second disc
Hi guys. Can someone help? I'm trying to add a second disc to my x-raid volume. This is the second time I've tried. The first was with my original in slot 1. That failed, so I tried turning the NAS...
Migroo
Nov 17, 2012Aspirant
Hi evan,
Thanks again for looking at this.
I can confirm that I used WD tool Data LifeGuard Diagnostic to write zeros and then check the disk. Everything was 100%.
I can email you a copy of the tool report if you like, but summary is as follows:
Test Option: EXTENDED TEST
Model Number: WDC WD20EARX-00PASB0
Unit Serial Number: WD-WMAZA8698712
Firmware Number: 51.0AB51
Capacity: 2000.40 GB
SMART Status: PASS
Test Result: PASS
Test Time: 22:30:01, November 11, 2012
Please clarify your last sentence? I have a 2-bay device (ReadyNas Duo v2) - can I not do XRAID with these hard drives?
SMART Status: PASS
Test Result: PASS
