Migroo
Jun 05, 2012Aspirant
Duo v2 - Can't add second disc
Hi guys. Can someone help? I'm trying to add a second disc to my x-raid volume. This is the second time I've tried. The first was with my original in slot 1. That failed, so I tried turning the NAS...
Migroo
Nov 27, 2012Aspirant
evan wrote: smartctl can not open the disk, could you use WD tool (Western Digital Data LifeGuard Diagnostics - DLGDIAG for Windows
) in Whindows to write zeros? then do quick test using the tool, if it is OK, hot insert to Duo v2.
You had better not use WD Green disk do RAID, because WD officially doesn't support RAID user cases in more than 2-bay device for WD Green disk.***** Disk SMART log for channel 2 [sdb] *****
smartctl 5.42 2011-10-20 r3458 [armv5tel-linux-2.6.31.8.duov2] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
Smartctl open device: /dev/sdb failed: No such device or address
Hi Evan
OK, sorry for the delay, but I finally did exactly what you wanted.
I used DLDIAG to write zeros (Quick Mode) and then did a quick test. Everything came back OK.
I then HOT inserted into bay 2.
I got the usual notifications in the info centre:
Tue Nov 27 21:38:20 GMT 2012
RAID sync finished on volume C. The array is still in degraded mode, however. This can be caused by a disk sync failure or failed disks in a multi-parity disk array.
Tue Nov 27 21:36:02 GMT 2012
RAID sync started on volume C.
Tue Nov 27 21:35:40 GMT 2012
Data volume will be rebuilt with disk 2.
Tue Nov 27 21:35:29 GMT 2012
New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 2]
What is the next step?
