CloudSys
Jun 17, 2017Aspirant
Guys, any idea about this uninvited Email address "[email protected]"? When I create any file on my NAS (ReadyNAS OS 6.7.4) a user with the ID "[email protected]" becomes the owner of the objects. I go...
Jun 17, 2017Guru - Experienced User
It might be wise to block it's internet connection while you are troubleshooting it.
Did you try the reset control for the share (shares page, the click on the settings wheel for the share, Choose "settings" and then the file access page.
- CloudSysJun 18, 2017Aspirant
Thanks for the advice.
I am trying to remove this suspicious user ID; I did reset the permissions on File Access tab but does not help with the issue. The ID ([email protected]) has been mistiriesly created when the very first admin user is defined at the ReadyNAS Accounts>Users page when I defined the New User. Though I created the first admin user with the correct ID (and still in the Account>User page the first user shows up with the legitimate ID) but any object at my NAS without Guest access has an owner [email protected] :mansad:
I am going to delete the first user and recreate again to see the effect.
- StephenBJun 18, 2017Guru - Experienced User
You might consider using paid Netgear support, to help sort out what is going on.
No content to show
