MISSION
Nov 08, 2016Aspirant
email settings not changing, they just reverting back to original settings.
Did a fresh install on one of my many readynas boxes 314 . After an upgrade to 6.6.0 went all wrong. During the wizard set up section of the reset, an email settings was supplied. Everything is ...
- Nov 10, 2016
Hi MISSION,
Thank you for feedback. Might be best if you register the device so that we can check if there is still support.
FramerV
Nov 09, 2016NETGEAR Employee Retired
Hi MISSION,
Do you have an option to "Apply" when you select Reset on the drop down menu?
Have you also tried different browsers? Maybe clear the cache?
Would be best also if you register your ReadyNAS to check warranty status.
- MISSIONNov 09, 2016Aspirant
if you select reset option the button says apply.
once applied the page refreshes and says," service to send alerts not configured".
The page settings are then still pre populated with old settings.
If I type over this and supply new settings, the button says test and apply.
This works fine and the test email is correct with new settings and all further alerts use new settings.
However the old settings are still on to the page so it doesnt represent what it actually is.
Yip tried the usual things empty cache and a different browser even went on a different machine. all the same old settings are displayed.
I also went on a few of my other 102 RN and noticed they do the same and they havent been upgraded to latest 6.6.0
It works with new setting but just doesnt display them so its inaccurate info.
Dont think there is much i can do about this, maybe someone will have a look at it in the next update.
- FramerVNov 10, 2016NETGEAR Employee Retired
Hi MISSION,
