MISSION's avatar
MISSION
email settings not changing, they just reverting back to original settings.
Did a fresh install on one of my many readynas boxes 314 . After an upgrade to 6.6.0 went all wrong.   During the wizard set up section of the reset, an email settings was supplied. Everything is ...
  • FramerV's avatar
    FramerV
    Nov 10, 2016
    Hi MISSION,
    Thank you for feedback. Might be best if you register the device so that we can check if there is still support.
ProSupport for Business
