Calvin386
Jul 23, 2018Aspirant
Enable DLNA Ready NAS 212
I would like to view pictures stored on my ReadyNAS 212 on my LED TV via Dish Hopper receiver. I can see the ReadyNAS on the Hopper but cannot see the content (Folder etc...) on the NAS. After search...
Jul 23, 2018Guru - Experienced User
Calvin386 wrote:
After searching for a solution, it appears I need to enable DLNA on my NAS.
Is this a good idea? Are there inherent risks to enabling DLNA?
Often you will need a DLNA server running on the NAS if you want to watch media on a smart TV. Another option is see if the TV has a plex app available - if so you could use plex.
DLNA is a local service, and it is not something that can be used over the open internet.
You need to enable the DLNA service itself on the system->settings->services page, and then enable DLNA on each share that holds media using the settings wheel for those shares (on the shares page).
- Calvin386Jul 23, 2018Aspirant
It appears that my Sony Bravia does support Plex. I think I will try that first since it is supported by the NAS and LEDtv. The Hopper Home Media app appears to be shaky at best.
Thanks
