Calvin386
Jul 23, 2018Aspirant
Enable DLNA Ready NAS 212
I would like to view pictures stored on my ReadyNAS 212 on my LED TV via Dish Hopper receiver. I can see the ReadyNAS on the Hopper but cannot see the content (Folder etc...) on the NAS. After search...
Jul 23, 2018Guru - Experienced User
Calvin386 wrote:
After searching for a solution, it appears I need to enable DLNA on my NAS.
Is this a good idea? Are there inherent risks to enabling DLNA?
Often you will need a DLNA server running on the NAS if you want to watch media on a smart TV. Another option is see if the TV has a plex app available - if so you could use plex.
DLNA is a local service, and it is not something that can be used over the open internet.
You need to enable the DLNA service itself on the system->settings->services page, and then enable DLNA on each share that holds media using the settings wheel for those shares (on the shares page).
Calvin386
It appears that my Sony Bravia does support Plex. I think I will try that first since it is supported by the NAS and LEDtv. The Hopper Home Media app appears to be shaky at best.
Thanks
