bozolino1
Mar 29, 2011Aspirant
Enabling https for Subsonic?
the offical subsonic "getting started" page at http://www.subsonic.org/pages/getting-started.jsp gives these instructions: 4 Using https For improved security you can turn on https encryptio...
fdullemond
Dec 27, 2011Aspirant
If you are running this from work, you might really consider running subsonic using https to avoid traffic monitoring...
[paranoid mode=on]
With http your subsonic credentials will be transported in the clear.... not the most optimal arrangement to run over the internet.
[/paranoid]
[paranoid mode=on]
[/paranoid]
