Nate_Cochrane
Jan 07, 2014Aspirant
Every HDD I put in Pro Pioneer fails: What is wrong?
So I started getting creeping SMART errors on disk 4 (2TB WD2003FYYS) of my Readynas Pro Pioneer. Seeking to avoid a calamity, I checked the HCL, asked around the Readynas forums and decided on a Netg...
Nate_Cochrane
Thanks, mdgm, I may have to do that but I'd like to exhaust other possibilities before I try the nuclear option. There's 7TB on the array and no easy way for me back it up, especially since if it's a hardware problem a factory default won't help.
Is there any way to test the RAID controller? Do you know what have others have done in this circumstance?
Many thanks for your continued support.
