Nate_Cochrane
Jan 07, 2014Aspirant
Every HDD I put in Pro Pioneer fails: What is wrong?
So I started getting creeping SMART errors on disk 4 (2TB WD2003FYYS) of my Readynas Pro Pioneer. Seeking to avoid a calamity, I checked the HCL, asked around the Readynas forums and decided on a Netg...
Jan 08, 2014Guru - Experienced User
You can migrate your disks to your friends NAS (powered down of course). It's best to label the drives by slot number as you remove them. If your friend's system is not running 4.2.25, it would be best if you updated it before you migrated. Otherwise it will attempt to downgrade your OS to whatever firmware he is running.
Then make/update a backup if you don't have one.
You can then try inserting the Hitachi by itself into your pro, and see if that installs. Use the same slot you inserted it in before. If it works, then it seems likely that it is the PSU.
