escajo
Jan 12, 2015Aspirant
Expanding a ReadyNas Ultra 2
Hi, I'm new. I have a ReadyNas Ultra 2 with two 2Tb discs and I'm interested in increase the capacity to 6Tb changin the current 2Tb discs for two 3Tb discs. I do not need to preserve de data in the...
RX
Jan 12, 2015Luminary
escajo wrote: I have a ReadyNas Ultra 2 with two 2Tb discs and I'm interested in increase the capacity to 6Tb changin the current 2Tb discs for two 3Tb discs.
I do not need to preserve de data in the discs.
My version is Radiator 4.2.15.
Is it possible to do this?
Here is how:
1. Be sure to have a backup of all the data.
2. Power off your NAS. Pull-out the old 2x2TB disks.
3. Insert the new 2x3TB disks. Be sure its compatible with your ReadyNAS Ultra 2. Check the compatibility list of hard drives here: http://www.readynas.com/app/hcl_disk
4. Do a factory reset: http://kb.netgear.com/app/answers/detail/a_id/21100'
5. Select Flex-RAID then choose RAID 0 on the initial setup since you want to maximize the storage capacity to 6TB.
6. After setting it up, restore back your data to your NAS.
escajo wrote: Do I need to upgrade the firmware?
Now I can login by SSH. Will I be able to login after upgrading the firmware? I need to access by SSH in order to change some file permisions.
It would be best that you update the firmware to the latest version which is v4.2.27. You can download it here: http://kb.netgear.com/app/answers/detail/a_id/25755
You may access this link as your reference guide to locally update the firmware on your NAS: http://kb.netgear.com/app/answers/detai ... ultra-plus
If are not able to login via SSH on your NAS again after upgrading the firmware then download ToggleSSH on this link then install it on your NAS just like installing an Add-On: http://www.readynas.com/download/addons ... .0-x86.bin
