escajo
Jan 12, 2015Aspirant
Expanding a ReadyNas Ultra 2
Hi, I'm new. I have a ReadyNas Ultra 2 with two 2Tb discs and I'm interested in increase the capacity to 6Tb changin the current 2Tb discs for two 3Tb discs. I do not need to preserve de data in the...
mdgm-ntgr
Jan 12, 2015NETGEAR Employee Retired
You need to update the firmware before putting the higher capacity disks in.
4.2.15 only supports disks up to 2TB in capacity.
In 4.2.16 we added support for disks larger than 2TB in capacity.
If you don't want redundancy I would suggest creating a separate RAID-0 volume for each disk. With RAID-0 if a disk fails all data on the volume using that disk is lost.
To create separate Flex-RAID RAID-0 volumes you could delete the volume created automatically when choosing Flex-RAID then create the volumes you want.
