Ney
Jul 18, 2020Aspirant
Expanding from 1 to 2 disks, and creating raid1 (without losing data)
Hi, Short question: Can I have 1 disk in my readynas ultra (running os6) with data on it, add an additional drive (same size) and change the volume to raid 1 without losing the data? (I have trie...
- Jul 18, 2020
Ney wrote:
Hi,
Short question: Can I have 1 disk in my readynas ultra (running os6) with data on it, add an additional drive (same size) and change the volume to raid 1 without losing the data? (I have tried reading the knowledge base, but cannot get a clear answer)
Yes. The default XRAID setting will do this.
With your process, you should
- hot insert the second drive
- format it from the volume page
After the formatting completes, the NAS will convert the volume to RAID-1.
Jul 18, 2020Guru - Experienced User
Ney wrote:
Hi,
