NASguru's avatar
NASguru
Apprentice
Dec 07, 2016
Expanding volume on 626 - Raid 5 to Raid 6 not automatic
A quick note, the RN626X is not listed in the Model drop down when starting a new converstation.  So I choose the 716X which is close enough.  That said, I recently expanded the volume on my 626 from 4x4TB to 6X4TB.  The existing volume was Raid 5, but I was expecting it to automatically migrate over to Raid 6 after adding the 6th drive.  However, this did not happen so I'm guessing it requires manual intervention and if true then I fear the existing volume may be destroyed in the process.  Can any confirm the process either way?
Before the upgrade:
After the upgrade:
  • You had to disable X-RAID and choose the next disk added to add parity, add that disk and then you could have re-enabled X-RAID again.
    Now all the drive bays are full it's too late to convert the existing volume to RAID-6.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    It won't migrate to RAID-6 unless you tell it to. So now destroying the volume would be necessary to switch to RAID-6.
    • NASguru's avatar
      NASguru
      Apprentice
      That's a bummer since it would have been nice to know this in advance.  I like the idea of having 2 redundant drives but not if I have to destroy the existing volume to achieve it.  Although, Raid-5 does provide more volume so I guess that's a positive.  Anyhow, what is the process to move from Raid-5 to Raid-6 should I want to do this in the future?  I don't see Raid-6 as an option when clicking on X-Raid button.  The only option is for Flex-Raid.  I suspect a factor reset would get it done and the option for Raid-6 would be present then?
        mdgm-ntgr
ProSupport for Business
