stareck
Jan 08, 2015Aspirant
Expansion and encryption on RN104
Hello, I have the RN104 (firmware 6.2.2) My drives are: 1x1TB Western Digital Red - WD10EFRX 2x4TB Western Digital Red - WD40EFRX. First I created a X-RAID volume with encryption on 1TB disk. ...
Jan 08, 2015Guru - Experienced User
Just noticed this post by skywalker (netgear) from last April.
viewtopic.php?f=160&t=76049&p=423650&hilit=encryption+expansion#p423557
If this is still true, then the way forward is to replace your 1 TB drive with a 4 TB model, or do a factory reset with 2x4TB in place (which will delete data, apps, etc).
This appears to be an expansion limitation, not a volume size issue.
Skywalker wrote: Expanding encrypted volumes is a little more restrictive -- we can't do multi-level (mixed disk size) encrypted volumes. If you swap the remaining 500GB drives for 3TBs, it should expand.
