reburns
Sep 19, 2016Aspirant
Expansion failed - Pro Pioneer 6
Hello - Adding a 6th HDD to this Pro Pioneer failed. I believe that this was built using 4 each 4TB HDDs and later adding a 5th and now attempting to add a 6th. Is the issue a 8TB expansion lim...
Sep 19, 2016Guru - Experienced User
If a Netgear moderator requests logs, you email them using this procedure: http://kb.netgear.com/app/answers/detail/a_id/21543/~/how-do-i-send-all-logs-to-readynas-community-moderators
reburns wrote:
Adding a 6th HDD to this Pro Pioneer failed. I believe that this was built using 4 each 4TB HDDs and later adding a 5th and now attempting to add a 6th. Is the issue a 8TB expansion limit?
There is an 8 TiB growth limit, but you didn't exceed that.
The problem is the other constraint on growth - a volume cannot grow over a 16 TiB size. After 5 disks you were at 16 TB (~ 14.5 TiB), the 6th would take you to 20 TB (~ 18.1 TiB).
What you can do is back up all the data and do a factory reset with all drives in place. Though the volume can't expand to more than 16 TiB, the NAS will create a 20 TiB volume if you do this.
Since you are facing a factory reset anyway, you could take the opportunity to switch to OS 6 - which has no known expansion limits, and which has other features that aren't available with OS 4.2. One thing to factor in - you will lose Netgear support.
- reburnsSep 19, 2016Aspirant
Ok, I'll consider a factory reset and OS 6. AFAIK, the 4TB HDDs I am using is outside Netgear support already. (?)
Can you point me to directions for upgrading to OS 6?
- StephenBSep 20, 2016Guru - Experienced User
The legacy HCL aren't updated very often. Though the pro pioneer list does include three 4 TB models, including both WD Red drives and the Seagate VN drives (now branded as "Ironman").
See the highlighted post in this thread ( https://community.netgear.com/t5/Using-your-ReadyNAS/OS6-now-works-on-x86-Legacy-WARNING-NO-NTGR-SUPPORT/m-p/897023/highlight/true#M50465)The cliff-notes version is
1. Install the add-on PREP4TOR6_0.1-x86.bin. Don't reboot.
2. Install the firmware R4toR6_latest.bin
3. RebootThe reboot will automatically trigger a factory reset, which of course destroys the data on the NAS and the configuration.
- reburnsSep 20, 2016Aspirant
How robust is the OS 6 on a Pro Pioneer? As a casual user, I have no real complaints about the current OS...and often subscribe to the "if it ain't broke, don't fix it" logic. Although my Pioneer is out of warranty, its possible that I talk to Netgear suppor someday, although this forum is my first stop. FWIW, I do have OS 6 on my 2nd ReadNAS (RN316).
The WD40EFRX 4TB HDDs I'm using in the Pro Pioneer are now included in the compatability list.
Thanks!
