gryhnd
Oct 01, 2013Aspirant
Expansion with drive not on HCL
ReadyNAS 104, with 3x2TB Seagate drives on the HCL in X-RAID (RAID5) Receiving support aside, because I know that's an automatic "no"... I happen to now have a spare, but perfectly functioning 2...
Oct 02, 2013Guru - Experienced User
The RN104 firmware does not enforce the HCL.
If the Hitachi fails later, the array would be intact but unprotected. Any other problem would destroy the array, You would need to replace the drive to re-establish redundancy.
The other "automatic" - RAID is not a substitute for backup. If you don't have a backup plan in place, you should address that.
