NASguru
Dec 23, 2012Apprentice
EXT3 vs EXT4
I have not upgraded to 4.2.22 yet since the only benefit for me would be support for EXT4. The other fixes don't apply to how I use the NAS currently and of course I don't want to take a chance on in...
NASguru
mdgm wrote: Ah, good point. Should have noticed which forum it was in.
Unless you are having problems backing up to your EXT3 formatted USB disk I can't see much point changing to using EXT4. EXT4 adds support for files larger than 2TB in size and volumes above 16TB in capacity amongst other things. The first wouldn't be needed by many users and the latter is impossible with the USB drives available today.
Well, I was having issues initially with the NAS disconnecting from my external USB drive after running a backup job. However, I got that all sorted out. I don't have any files larger than 2TB so that wouldn't be an issue with the current format of EXT3. :D I was just more curious what performance increase if any would be realized using EXT4 over EXT3 and it doesn't sound like there is any. Per my Rsync calculation in the logs, I'm seeing about 28 MB/s - 29 MB/s on transfer speeds for files over 3GB in size. Per Wikipedia: USB 2.0: Released in April 2000. Added higher maximum signaling rate of 480 Mbit/s (effective throughput up to 35 MB/s or 280 MBit/s) (now called "Hi-Speed"). In short, I'm close to the effective throughput rate and hence why I asked.
