teo2710
Dec 14, 2015Aspirant
External USB ID (ie. USB_HDD_1) name keeps changing
As the subject title describes, my external usb drive ID doesn't stay the same. It changes every now and then from USB_HDD_1 to 2 and so on. I have two external USB drives, currently they have progre...
- Dec 15, 2015
You can reset the name if you have ssh access.
Remove usb disc from unit
login to readynas via putty , user = root - your admin password
goto /etc/frontview/usb
edit the file "usb-map" using editor of choice remove/clear all entries
save file
plug usb disk back in and it should be back to usb_hdd_1
BrianL2
Dec 14, 2015NETGEAR Employee Retired
Hi teo2710,
Were the drives safely removed (there's an icon in the admin page) before you unplugged them? Also, connect them to a PC and run windows error-checking tool.
Kind regards,
BrianL
NETGEAR Community Team
