teo2710
Dec 14, 2015Aspirant
External USB ID (ie. USB_HDD_1) name keeps changing
As the subject title describes, my external usb drive ID doesn't stay the same. It changes every now and then from USB_HDD_1 to 2 and so on. I have two external USB drives, currently they have progre...
- Dec 15, 2015
You can reset the name if you have ssh access.
Remove usb disc from unit
login to readynas via putty , user = root - your admin password
goto /etc/frontview/usb
edit the file "usb-map" using editor of choice remove/clear all entries
save file
plug usb disk back in and it should be back to usb_hdd_1
Davexyz2
Dec 15, 2015Aspirant
save file
- BrianL2Dec 15, 2015NETGEAR Employee Retired
Hi teo2710,
I hope you can try our suggestions and provide feedback by updating this thread.
Kind regards,
BrianL
NETGEAR Community Team - teo2710Dec 16, 2015Aspirant
Many thanks for showing me how to reset it back to USB_HDD_1 and USB_HDD_2 respectively.
I had been ejecting it the proper way via the admin page. Don't know why it has shifted to numbers 4 and 5 over time.
Might have to keep an eye on it from now on.
- BrianL2Dec 16, 2015NETGEAR Employee Retired
Hi teo2710,
Just update this thread if the issue reoccurs.
Kind regards,
BrianL
- farmersLSDJan 15, 2016Tutor
Thanks for the solution, but really, NETGEAR? You can make this doable in the interface?
- mdgm-ntgrJan 15, 2016NETGEAR Employee Retired
There isn't a UI option to clear the list of USB disks.
- farmersLSDJan 20, 2016Tutor
I know there isn't. That's my point...
There should be, and I can't imagine it being that hard.
