teo2710
Dec 14, 2015Aspirant
External USB ID (ie. USB_HDD_1) name keeps changing
As the subject title describes, my external usb drive ID doesn't stay the same. It changes every now and then from USB_HDD_1 to 2 and so on. I have two external USB drives, currently they have progre...
- Dec 15, 2015
You can reset the name if you have ssh access.
Remove usb disc from unit
login to readynas via putty , user = root - your admin password
goto /etc/frontview/usb
edit the file "usb-map" using editor of choice remove/clear all entries
save file
plug usb disk back in and it should be back to usb_hdd_1
Davexyz2
Dec 15, 2015Aspirant
save file
teo2710
Dec 16, 2015Aspirant
Many thanks for showing me how to reset it back to USB_HDD_1 and USB_HDD_2 respectively.
I had been ejecting it the proper way via the admin page. Don't know why it has shifted to numbers 4 and 5 over time.
Might have to keep an eye on it from now on.
- BrianL2Dec 16, 2015NETGEAR Employee Retired
Hi teo2710,
Just update this thread if the issue reoccurs.
Kind regards,
BrianL
NETGEAR Community Team
