teo2710
Dec 14, 2015Aspirant
External USB ID (ie. USB_HDD_1) name keeps changing
As the subject title describes, my external usb drive ID doesn't stay the same. It changes every now and then from USB_HDD_1 to 2 and so on. I have two external USB drives, currently they have progre...
- Dec 15, 2015
You can reset the name if you have ssh access.
Remove usb disc from unit
login to readynas via putty , user = root - your admin password
goto /etc/frontview/usb
edit the file "usb-map" using editor of choice remove/clear all entries
save file
plug usb disk back in and it should be back to usb_hdd_1
teo2710
Dec 16, 2015Aspirant
Many thanks for showing me how to reset it back to USB_HDD_1 and USB_HDD_2 respectively.
I had been ejecting it the proper way via the admin page. Don't know why it has shifted to numbers 4 and 5 over time.
Might have to keep an eye on it from now on.
BrianL2
Dec 16, 2015NETGEAR Employee Retired
Hi teo2710,
Just update this thread if the issue reoccurs.
Kind regards,
BrianL
NETGEAR Community Team
