blacketg
Oct 26, 2012Aspirant
Factory reset still going after 20 hoours?
Hi All I have a V1 Duo with 2 * 1TB disks that I've been playing with to try out music streaming. I managed to forget what I'd changed the admin password to (lesson learnt) and decided to do a f...
Oct 27, 2012Guru - Experienced User
HERBIEO wrote: Not sure if i have misunderstood you but in your first post you stated that you have just done a factory reset,
when you factory reset the unit as StephenB pointed out this resets admin password to netgear1
You apparently missed this followup:
blacketg wrote: There's been a 'development'. The power lead got knocked out, and when re-connected the NAS has gone back to 'normal'. I can now see it in RAIDar and in Windows Explorer. None of the data has been wiped. Should I manually delete the data and try again? I can't get through to 'Setup' - it asks for an admin password and I can't seem to give it the right combination.
It isn't clear what exactly was happening in the first step, though it does not appear to have been a factor reset.
Anyway, I think an OS reinstall is the right next step. Once he can get into the NAS again, he can sort out if there is any benefit to doing the reset.
