dhl
Oct 28, 2014Luminary
Failed FrontView backup, how to fix?
Hello All, Two days ago, I started getting this error backing up one of my shares to a USB drive via FrontView: INCREMENTAL Backup started. Tue Oct 28 02:05:02 PDT 2014 Job: 003 Protocol: loc...
dhl
mdgm wrote: What filesystem is on the USB disk?
I/O errors do suggest there may be a hardware problem with a disk.
Can you send me your logs zip file (see ink in my sig)?
The USB disk is formatted EXT4.
Agree that I/O suggests hardware, but also thinking there may be something weird going on with permissions. The files in question were created by Carbon Copy Cloner and I've recently had issues with CCC setting file/directory visibility to invisible after the backup job. Mike Bombich's support is excellent and he helped me fix the problem, but I wonder if some residual cruft is messing up FrontView.
Zip file sent. Thanks for your help!
--dhl
