dhl
Oct 28, 2014Luminary
Failed FrontView backup, how to fix?
Hello All, Two days ago, I started getting this error backing up one of my shares to a USB drive via FrontView: INCREMENTAL Backup started. Tue Oct 28 02:05:02 PDT 2014 Job: 003 Protocol: loc...
dhl
Oct 29, 2014Luminary
Update:
The backup worked properly after I removed the CCC problem directory from the source. After a bit more testing, I found that the CCC problem directory on the USB destination is corrupt is the source of the I/O error. I tried removing it in terminal but it doesn't delete:
I have a support request open with Mike Bombich since CCC is the source of the problem so hopefully he'll be able to help. I think there may be a couple files in the directory with bad visibility or permission flags that are making rm balk.
In any event, the USB drive seems fine for now, but this motivates me to deal with the bigger backup issue I've been putting off this year...
localhost:FCPX Libraries dhl$ sudo rm -r corrupt_folder
Password:
rm: corrupt_folder: Invalid argument
