dhl
Oct 28, 2014Luminary
Failed FrontView backup, how to fix?
Hello All, Two days ago, I started getting this error backing up one of my shares to a USB drive via FrontView: INCREMENTAL Backup started. Tue Oct 28 02:05:02 PDT 2014 Job: 003 Protocol: loc...
mdgm-ntgr
Dec 01, 2014NETGEAR Employee Retired
Both should be pretty good. The 516/716x would be the logical upgrade path from the Pro 6, especially after the CPU upgrade.
The 316 is good model. It's not as fast as Pro 6 or the 516 though.
What do you use the NAS for? That will help determine if you need the extra processing power or not.
