Samsurance
Jan 21, 2017Aspirant
Fan Problem After Upgrading To 6.6.1
It might have been coincidence but a day after I had upgraded to ver 6.6.1, I received a "The device is shutting down because Disk-1 has exceeded 60 deg C" message (or something like that), and I fou...
mstick
Feb 15, 2017Aspirant
I am having the same problem, only I tried a new fan thinking the fan was the problem. I do wish NETGEAR would fix this soon. Meanwhile I have a USB powered fan keeping my NAS cool enough to run.
aalexandrebeta
Feb 16, 2017Master
6.7.0 FW is underway!
- SamsuranceFeb 16, 2017Aspirant
Good to know. I hope v6.7.0 is better at resolving rather than creating issues. Another observation I'd like to add is after the fan miraculously started working again, it continues to run even after the RN102 is powered down. The only time it stops is when the main workstation I primarily use to access the RN102 is powered down. Go figure...
- aalexandrebetaFeb 16, 2017Master
That is strange, are you residing in Roswell or near Area 51, you can call Tony Stark to solve your issue!! S.H.I.E.L.D can solve it too!!
I am just joking! ( Too much binge late shows watching!!)!!!
- mstickFeb 17, 2017AspirantAnd now my fan is working again. I noticed also that the little image of the rotating fan and control have returned to the System > Performance screen. I hope it keeps working, but I'm keeping my little USB-powered fan nearby just in case.
- SamsuranceFeb 17, 2017Aspirant
Yours appears more "miraculous" than mine because you just chilled and the fan worked again. In my case I physically removed the fan (only to find out it was good), which suddenly worked when I ressembled the unit. In my 2nd posting, I said my "Fan Alert" was toggled ON but I never received an alert it wasn't doing it's job. Instead, I received an HD overheating alert. Like the other guy said, I hope v6.7.0 resolves this issue.
