redstamp
Jul 10, 2016Apprentice
File explorer and management for my ReadyNAS
I have been using my ReadyNAS 104 now for a few weeks. Generally very impressed - and for the price it is unbeatable. The only one thing I am surprised at is the file management interface and capab...
- Jul 17, 2016
Got it working!!
Based on your explanation of the issue, I just cleaned out all network mappings with net use * /delete, manually disconnected WinExplorer mappings and deleted all credentials and rebooted.
When re-started, I network mapped in WinExplorer checking the 'use other credentials' - then entering the cloud user credentials from my NAS. Used the NAS name (not the IP address) in the network mapping and checked the keep credentials and re-connect at logon. When creating more drive mappings to the same NAS, I followed the same process, but didn't try and enter new credentials ('cos it errors if I did).
Hey presto, all shares mapped to drives and persist at login.
Thanks greatly for pointing me in the right direction, and helping me to find a little more about net use, Windows credentials manager and to keep persisting ;-)
Jon
redstamp
Jul 17, 2016Apprentice
Just realised what I was doing wrong - you meant '\data' as the name of one of my shares on the NAS - sorry and corrected.
Now when trying to use user:admin, then get System Error 86 - specified network password is not correct
When trying to use user:nascloudusername, then works fine (like it did from WinExplorer), but if I add the persistent switch when remapping this drive and reboot, windows wont re-connect and throws an error ref multiple users with same username (which is what I suspect you meant in your post and why we're trying to get the IP connection to use admin...
redstamp
Got it working!!
Jon
