schwizer
Aug 04, 2016Aspirant
Folders missing when backing up folder on PC to Readycloud
Using a ReadyNas 104 with 4 WD Red 3TB discs in Raid 5. Windows 10. Desktop ReadyCloud Client v1.12. when i use the desktop app to back up a folder, say for example D:\Users\user\My Documents ...
JennC
Aug 06, 2016NETGEAR Employee Retired
Hello schwizer,
Have you checked if these folders that were not backed up to the NAS have any permissions? Also, what is the current firmware version?
schwizer
Aug 07, 2016Aspirant
Latest firmware 6.5.1.
Here is what i have tried.
1) copy all files & folders from "My Documents" to a folder on the desktop and then back up that desktop folder with the desktop app the same way. This works, the desktop app backs up all the files in the new location
2) log into admin page and delete the "My Documents" folder from the web interface by typing "DESTROY" and then go back to desktop app, syncronize (My documents) folder is gone from desktop app and then try to sync it again. The desktop app says imediately sync complete but when i click the folder on the desktop app,the ReadyNas folder opens and it's empty.
Any ideas?
Schwizer
- schwizerAug 07, 2016Aspirant
Oh sorry and the permissions were the same on both folders the one that worked and the one that didnt except for one permission for the homegroup (the documents folder is shared with home group).
3 permissions for each folder, one for the system, one for my username and one for Administrators
Schwizer
- JennCAug 09, 2016NETGEAR Employee Retired
Hello schwizer,
When you back up a folder from your cmoputer to the NAS using ReadyCloud desktop client, it creates a new share that is randomly named. Have you checked that share in the admin page instead if it has all the files?
- JennCAug 12, 2016NETGEAR Employee Retired
Hello schwizer,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
