tjech
Oct 01, 2015Aspirant
Folders not listing (maybe after Firmware upgrade)
Hi there, I have a problem with folders for my Music share not displaying through AFP or SMB (eth or Wifi). AFP/SMB/DLNA are enabled.I am using a Macbook Pro for connecting. Network perms ar...
JennC
Oct 09, 2015NETGEAR Employee Retired
Hello tjech,
Welcome to the community!
If the Sonos sees the share and can play it then it means the NAS is sharing it. What OS of computer are you using to access the Music folder and not being able to see it? Have you tried using the "net use * /delete" command to disconnect from the share drive then re-map?
Have you tried on another computer?
