Equinox1
Mar 29, 2015Guide
From 104 to Pro 6
Both the 104 and the Pro 6 are running OS6.2. Can I just move the disks from the 104 to the Pro 6 directly?
mdgm-ntgr
Mar 29, 2015NETGEAR Employee Retired
That should work. Would be best to be running the latest 6.2.3 Beta on both systems before doing the migration.
Update both to that firmware, verify the update is successful, power down, remove the disks from both NAS units (label order), move the disks from the 104 across and then power on.
