Equinox1
Mar 29, 2015Guide
From 104 to Pro 6
Both the 104 and the Pro 6 are running OS6.2. Can I just move the disks from the 104 to the Pro 6 directly?
itsjasper
Apr 05, 2015Luminary
No, the apps are architecture-specific. The 104 CPU is ARM, the Pro is x86.
The 100 series is the lowest spec CPU out of the entire lineup - fine for general file serving but would be limited for app performance.
