Paddy132a
Mar 01, 2014Aspirant
Frontview not showing after add-on instal
NETGEAR RNDP600U ReadyNAS Ultra 6 Plus RAIDiatar 4.2.26 This system has been running fine for 18 months. Today, I tried to install BZeet - the add-on seemed to work fine but now Frontview is appe...
vandermerwe
Mar 01, 2014Master
You could try deleting the addon if you can, although I suspect you can't if Frontview is not working, then doing an OS reinstall from the boot menu.
