Xatosch
Oct 19, 2016Apprentice
Frontview restarting since OS 6.6
Hi! Since 6.6 I see often in the logs the message: >> System: ReadyNASOS service or process (readynasd) was restarted. The admin page hangs and the content under shares, backup and so on is ...
mdgm-ntgr
Oct 19, 2016NETGEAR Employee Retired
Do you have a lot of snapshots?
Which firmware did you update from?
Can you send in your logs (see the Sending Logs link in my sig)?
- XatoschOct 19, 2016Apprentice
Yes, there are 14 shares/luns which makes every hour a snapshot. All this snapshots are backed up with ReadDR...
I have updated from the last version before 6.6, I think it was 6.5.2 ???
The logs are send...
