Thirutender
May 30, 2018Aspirant
FTP Error
Hi,
I have issue in connecting NAS with FTP using file zilla, shows below error while connecting
Status: Server sent passive reply with unroutable address. Using server address instead. Command:...
- May 30, 2018
Thirutender wrote:
No, it is not connecting but give error "Error: The data connection could not be established: ECONNREFUSED - Connection refused by server"
That status message isn't the reason for the failed connection.
Did you limit the passive port range in the NAS, and forward the full passive port range in the router?
Also, are your passive ports in the dynamic/private port range (49152-65535)? Ports outside that range will generally work, but it's best to use ports in the range that is reserved for private use. You definitely don't want to use ports < 1024 for this, as that can conflict with other services.
Note you can confirm that the passive ports are open for TCP using canyouseeme.org on your home network.
May 30, 2018Guru - Experienced User
That is a normal status - not an error - and you should be able to access the shares anyway. Is that the case?
It's actually telling you that it is triggering a FileZilla feature (which is to substitute the WAN ip address for the signaled local LAN ip address when making the data connection back to the NAS). You can eliminate the status message by configuring masquerading in the ReadyNAS FTP server - but if you do that you will most likely lose local FTP access. So it's best to just ignore it.
Thirutender
- StephenBMay 30, 2018Guru - Experienced User
- ThirutenderMay 31, 2018Aspirant
I opened passive ports in 55000 to 55050 router whereas in Readynas it is large range, so i modified as same as in router and now works good. Thanks for the help
