alokeprasad
Sep 03, 2014Mentor
Getting 6.5 MB/s transfers on a 1 GB full duplex connection?
Using Win 7.1, gigabit Ethernet connected to gigabit switch GS108, to a Duo (Sparc) using the latest firmware. The LED's on the switch is showing gigabit speeds. Frontview is showing the interface on...
mdgm-ntgr
Sep 03, 2014NETGEAR Employee Retired
What brand and model drives do you have installed in the NAS?
So you are running 4.1.13 on your ReadyNAS?
Note the Duo (v1) is essentially using the same CPU and memory as a product first released in 2006. Early NAS units with gigabit don't have anything like the performance of the new devices available today.
Can you disable Jumbo Frames and see what impact that has on performance?
For Jumbo Frames to work, the NAS, switch and PC all need to support it, have it enabled (if there is an option to enable it) and for the Jumbo Frames implementation to be compatible amongst all the devices.
- Jan 17, 2024Retired_Member
