melojms
Mar 17, 2015Aspirant
Hard Drive noise on Time Machine
Hello, I have been using a WD Green 2TB on my readynas 102, and I use Time machine. But when Time machine is backing up, drive makes lots of noise. I just changed the hard drive for a brand new WD...
melojms
The firmware I'm running is the 6.2.3 beta 9. The noise exists since I bought it, but I thought it was a problem with the drive. But since I changed the drive with a RED one, it can only be a matter of the firmware and the way it handles time machine (I guess?...)
I'll try to screw the drives in the bays with some rubber, but I don't think that will help.
