melojms
Mar 17, 2015Aspirant
Hard Drive noise on Time Machine
Hello, I have been using a WD Green 2TB on my readynas 102, and I use Time machine. But when Time machine is backing up, drive makes lots of noise. I just changed the hard drive for a brand new WD...
RX
Mar 18, 2015Luminary
@melojms:
To contact Netgear Support, check this link: http://support.netgear.com/general/contact/#tab-call -- just select the country where you are located.
