melojms
Mar 17, 2015Aspirant
Hard Drive noise on Time Machine
Hello, I have been using a WD Green 2TB on my readynas 102, and I use Time machine. But when Time machine is backing up, drive makes lots of noise. I just changed the hard drive for a brand new WD...
Mar 19, 2015Guru - Experienced User
You often will hear noise when hard drives seek. The reds are acoustically quiet, so the noises shouldn't be very loud. Of course you can't really tell the level of noise in the video clip.
