Dewdman42
Sep 17, 2017Virtuoso
hard linked home dir????
I have recently discovered an unusual and unexplainable thing on my readynas and I am hoping someone has some insight about it. Something has created a hard link to my home dir, calling it the same ...
- Sep 18, 2017
yep, readycloud is the one! I had to hit the "leave" button the readycloud screen in frontview and that nuked the folder. Need to learn a little more about how readycloud works...but thanks for that.
Sep 18, 2017Guru - Experienced User
Dewdman42 wrote:
/home/<email>/
/home is a mount, it should be showing you the same information as /data/home. Normally a folder there means that username of <email> was created by the system (and that someone logged into that account). ReadyCloud of course uses that convention, so you should look on the "cloud users" tab of the accounts page in the admin web ui.
Subvolumes all show an inode of 256 (and I believe each users's home folder is a btrfs subvolume).
Dewdman42
Sep 18, 2017Virtuoso
- Dewdman42Sep 18, 2017Virtuoso
I tell ya what's weird though. When I clicked the leave button that deleted the dir, but then when turned readycloud back on, the dir didn't come back again.. very strange! Anyway, that's what it is.
- StephenBSep 19, 2017Guru - Experienced User
In general you have to actually access the NAS shares using SMB in order for the home folder to be created for a user (cloud or otherwise). You would have done that if you'd run the ReadyNAS app on a device using those credentials.
