TonyKL
Feb 29, 2016Guide
Help compiling modules on ReadyOS 6.4.2 (required to route eth1 over tun1)
Hi all,
I'm wanted to route traffice from eth1 over a VPN connection via openvpn.
I've installed and configured openvpn and all is good however I believe I need support for netfilter in iptables to set this route up?
I've downloaded the sources for 6.4.2 and configured the kernel from the readynas config to enable the modules and rebuilt everything. However I'm unable to load the modules once they have been installed.
Modinfo appears to report the same information for the new modules compared to the existing shipped modules but I don't know why they wont load. I usually get 'invalud argument' when attempting to load.
Anybody correctly built modules on the readynas?
- WhoCares_Mentor
I ran into the same problem. Since 6.4.1 or 6.4.2 I can no longer build kernel modules on my VMs but have to build them directly on the ReadyNAS to get working versions. Don't know if it's the same problem for I'm mostly builting modules external to the kernel tree but you should see some additional messages when running
dmesg
after trying to load the module(s) in question.
-Stefan
- TonyKLGuide
Thanks for the reply, I'm actually trying to do this on the ReadyNAS as I didn't know how to do it from a VM.
I will try again on 6.4.2 as the kernel is updated. I get stuff like this in dmesg:
nf_conntrack: disagrees about version of symbol skb_copy_bits
nf_conntrack: Unknown symbol skb_copy_bits (err -22)
nf_conntrack: disagrees about version of symbol register_net_sysctl
nf_conntrack: Unknown symbol register_net_sysctl (err -22)
nf_conntrack: disagrees about version of symbol skb_make_writable
nf_conntrack: Unknown symbol skb_make_writable (err -22)
nf_conntrack: disagrees about version of symbol seq_open_net
nf_conntrack: Unknown symbol seq_open_net (err -22)
nf_conntrack: disagrees about version of symbol nf_afinfo
nf_conntrack: Unknown symbol nf_afinfo (err -22)
nf_conntrack: Unknown symbol nf_conntrack_destroy (err 0)
nf_conntrack: Unknown symbol nf_ct_destroy (err 0)
nf_conntrack: disagrees about version of symbol register_pernet_subsys
nf_conntrack: Unknown symbol register_pernet_subsys (err -22)
nf_conntrack: disagrees about version of symbol init_net
nf_conntrack: Unknown symbol init_net (err -22)
nf_conntrack: disagrees about version of symbol seq_release_net
nf_conntrack: Unknown symbol seq_release_net (err -22)
nf_conntrack: disagrees about version of symbol unregister_pernet_subsys
nf_conntrack: Unknown symbol unregister_pernet_subsys (err -22)
nf_conntrack: disagrees about version of symbol nf_log_packet
nf_conntrack: Unknown symbol nf_log_packet (err -22)
nf_conntrack: disagrees about version of symbol inet_proto_csum_replace4
nf_conntrack: Unknown symbol inet_proto_csum_replace4 (err -22)
nf_conntrack: Unknown symbol ip_ct_attach (err 0)
nf_conntrack: disagrees about version of symbol unregister_net_sysctl_table
nf_conntrack: Unknown symbol unregister_net_sysctl_table (err -22)
- WhoCares_Mentor
What's the actual command set you're running and is this an ARM or an Intel based ReadyNAS?
-Stefan
