Strange_alex
Nov 21, 2024Aspirant
Help. I think my ReadyNas Ultra6 is dying.
One day I did not find access to the storage. Looked at the NAS, it was not working, only blinking both LEDs. I turned it off, blew out the dust inside, and turned it back on. It was also blinking an...
- Nov 21, 2024
I agree this sounds like a power supply issue. While the volume is in re-sync, you should do nothing. But I hope you have a recent backup, as it could fail during re-sync in a way that makes the volume inaccessible.
Once the re-sync is complete, you can try booting the NAS with no drives. It's not a great test, but can be useful in some cases. If it boots more normally (up to the point of saying "no disks", of course), then that's another hint it is the supply.
If you have a spare ATX12V power supply (or one you can "borrow" from a PC), you can connect it externally just to see if that fixes it before you invest in a replacement supply.
Sandshark
Nov 21, 2024Sensei
Strange_alex
Nov 22, 2024Aspirant
Yesterday, I found a 20TB drive and started backing up just as I was syncing. Since I have a lot of shares, and I didn't want to copy several streams in parallel, the NAS stayed half a night without load and.... did not reboot. Although earlier, judging by the output of the 'last' command, it could reboot every few minutes. Just in case I stopped the tailscale daemon beforehand, which shouldn't affect it in any way, but the fact remains - no reboots yet.
Problems with the power supply are the main theory so far, I will look for a replacement. Might be worth taking it out and checking for blown capacitors. As soon as I copy the contents - I will try booting without disks as you advised.
Any other tests to check the power supply? I find it a bit strange that it reboots without load, but under load it is stable.
Does the blinking lights mean anything? Is it just a side effect of the disks not getting enough power to start?
