AlexSem
Mar 17, 2026Aspirant
Help needed: ReadyNAS NVX (RNDX4000) Restore to RAIDiator 4.2 - Empty /boot_flash
Hi everyone, I’m reaching out because I made a major mistake while attempting to upgrade my ReadyNAS NVX (RNDX4000) from v4.2 to OS6. The upgrade failed, and now I'm trying to restore the unit ba...
- Mar 21, 2026
AlexSem wrote:
Do you see any possible options for recovering the NAS?Check your PMs (click on the envelope icon in the upper right of the forum page).
Sandshark
Mar 18, 2026Sensei
I can't edit, but I realized I may not have been clear. The actual boot flash should still contain an OS6 image and your vpd while boot_flash is where the image is temporarily stored for an OS update.
AlexSem
Mar 18, 2026Aspirant
Thank you very much for taking the time and giving attention to my issue — I truly appreciate it.
Unfortunately, the boot_flash is indeed empty. Mounting this directory confirmed that it does not contain any files.
Using RAIDiator 4.2 USB Flash Recovery, I install version 4.2.31. The NAS boots successfully and is able to perform both an OS update and a factory reset. RAIDar for Windows detects the running device without any issues.
At the moment, the only problem is that the administration panel is empty and shows only the graphical layout. All control buttons in the left frame of the web interface are missing. At the same time, the /shares/ web interface is displayed correctly.
My first assumption was a problem related to the certificate and SSL 1.0. However, I was unable to get a proper administrative interface even when using Windows XP with IE6, or Windows 7 with Firefox ESR 54. Even after disabling the HTTP→HTTPS redirect, the administrative interface still does not load correctly over HTTP.
My next thought was to look into the error during update: '/boot_flash/vpd': No such file or directory. This error appears in the serial console, which is connected to my computer via an ESP32. By the way, I came up with this bridge solution due to the lack of a dedicated cable, and it works reliably in both directions.
I suspect that the absence of files in boot_flash is preventing the administrative interface from loading its active content correctly.
I am also confused as to why USB Flash Recovery is unable to mount boot_flash, while I can successfully mount it in Tech Support mode using the root password you kindly provided in your article “Backup and restore of VPD file.” I am able to read from and write to the mounted boot_flash partition without any issues.
At this point, my (possibly incorrect) understanding is that the problem lies in the inability to mount boot_flash during the USB Flash Recovery process, and that some parts of the administrative interface may actually be stored there.
- StephenBMar 19, 2026Guru - Experienced User
Are you seeing the correct vpd file when you are using tech support mode?
Did you manage to undo this:
echo -n "22N193RA00131" > /boot_flash/vpd/vpd- AlexSemMar 19, 2026Aspirant
Just to clarify, do you mean that I should completely remove the /vpd directory along with the /vpd/vpd file?
Yes, I can undo this if you believe it’s necessary.
However, based on my previous recovery attempts, it didn’t seem to make any difference whether this file was present on the disk or not. In all cases, I still see the error '/boot_flash/vpd': No such file or directory, as well as the missing administrative interface.
I’m ready to follow your further instructions.
Well, the real VPD file is binary and digitally signed by Netgear. So what you did certainly wouldn't resolve the problem and it might be getting in the way. I am wondering if you created the folder and file in the mount point (with the actual folder boot_flash folder not mounted).
I haven't looked at what is supposed to be in the folder (or the full boot flash drive) on my Pro 6, and I don't have an NVX. So I don't have direct experience on how you might recover from what you did. There is a post here from someone else who made your mistake:
What files are you seeing in the mounted boot_flash? Can you copy/paste the directory listing? Include the file sizes. (don't try a screenshot, as that functionality in the forum is broken. Instead select the text in the telnet session and use control-c to copy it.)
Also, when you connect to frontview, are you using https://nas-ip-address/admin ?
