AlexSem
Mar 17, 2026Aspirant
Help needed: ReadyNAS NVX (RNDX4000) Restore to RAIDiator 4.2 - Empty /boot_flash
Hi everyone, I’m reaching out because I made a major mistake while attempting to upgrade my ReadyNAS NVX (RNDX4000) from v4.2 to OS6. The upgrade failed, and now I'm trying to restore the unit ba...
- Mar 21, 2026
AlexSem wrote:
Do you see any possible options for recovering the NAS?Check your PMs (click on the envelope icon in the upper right of the forum page).
AlexSem
Mar 19, 2026Aspirant
1. Tech Support mode.
telnet (root)
# ls
bin dev init proc sys usr
boot_flash etc lib root sysroot var
data frontview mnt sbin tmp
# cat /proc/partitions
8 0 488386584 sda
8 16 125440 sdb
8 17 125333 sdb1
# find / -name "vpd"
/boot_flash/vpd
/dev/vpd
# ls -lh /dev/vpd
crw------- 1 60, 0 Mar 19 16:21 vpd
# ls -l /boot_flash/vpd
-rw-r--r-- 1 0 Mar 19 16:36 /boot_flash/vpd
# cat /boot_flash/vpd
# mount
rootfs on / type rootfs (rw)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
tmpfs on /dev type tmpfs (rw,relatime,size=10240k,mode=755)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
# cd boot_flash
# ls -l
-rw-r--r-- 1 0 Mar 19 16:36 vpd
# cat vpd
# rm vpd
# ls -l
/dev/vpd
Mar 19, 2026Guru - Experienced User
AlexSem wrote:1. Tech Support mode.
telnet (root)
It doesn't look like you tried to mount the real boot flash.
mount /dev/sdb1 /mnt
If that works, then try
ls /mnt
You should see something like this:
csums.md5 kernel.up root.tlz version.txt
initrd.gz ldlinux.sys supplmnt.tlz vpd
kernel memtest syslinux.cfg
Let us know what you see there.
- AlexSemMar 20, 2026Aspirant
# mount /dev/sdb1 /mnt
# ls /mnt
csums.md5 kernel memtest supplmnt.tlz version.txt
initrd.gz ldlinux.sys root.tlz syslinux.cfg
- StephenBMar 20, 2026Guru - Experienced User
initrd.gz ldlinux.sys root.tlz syslinux.cfgOk. So the VPD is indeed missing.
I'm not sure if the vpd showing in in the root in Sandshark's guide is a folder, or whether it is the vpd file itself. I'm tagging him, so hopefully he will answer.
Dear StephenB,
Thank you very much for joining in to help with my issue — I truly appreciate your time and support. I hope we will be able to resolve the problem and bring the NAS back to life.
