AlexSem
Mar 17, 2026Aspirant
Help needed: ReadyNAS NVX (RNDX4000) Restore to RAIDiator 4.2 - Empty /boot_flash
Hi everyone, I’m reaching out because I made a major mistake while attempting to upgrade my ReadyNAS NVX (RNDX4000) from v4.2 to OS6. The upgrade failed, and now I'm trying to restore the unit ba...
- Mar 21, 2026
AlexSem wrote:
Do you see any possible options for recovering the NAS?Check your PMs (click on the envelope icon in the upper right of the forum page).
Mar 19, 2026Guru - Experienced User
AlexSem wrote:1. Tech Support mode.
telnet (root)
It doesn't look like you tried to mount the real boot flash.
mount /dev/sdb1 /mnt
If that works, then try
ls /mnt
You should see something like this:
csums.md5 kernel.up root.tlz version.txt
initrd.gz ldlinux.sys supplmnt.tlz vpd
kernel memtest syslinux.cfg
Let us know what you see there.
AlexSem
Mar 20, 2026Aspirant
# mount /dev/sdb1 /mnt
# ls /mnt
csums.md5 kernel memtest supplmnt.tlz version.txt
initrd.gz ldlinux.sys root.tlz syslinux.cfg
- StephenBMar 20, 2026Guru - Experienced User
initrd.gz ldlinux.sys root.tlz syslinux.cfgOk. So the VPD is indeed missing.
I'm not sure if the vpd showing in in the root in Sandshark's guide is a folder, or whether it is the vpd file itself. I'm tagging him, so hopefully he will answer.
- AlexSemMar 20, 2026Aspirant
Dear StephenB,
Thank you very much for joining in to help with my issue — I truly appreciate your time and support. I hope we will be able to resolve the problem and bring the NAS back to life.
- SandsharkMar 21, 2026Sensei
vpd is a file at root of the actual boot flash. There must not be a vpd directory since it can't co-exist with the vpd file. My guess is that /proc/sys/dev/boot/info is created by the boot process from the data in the vpd file. Given it's in /proc/sys, it has to be put there by the system -- it's not a file on a drive (at least not in that location) .
- AlexSemMar 21, 2026Aspirant
- StephenBMar 21, 2026Guru - Experienced User
