guyworthy
Mar 19, 2013Aspirant
HELP post power failure
After a power failure, the checking file system stopped at 2%. I did not notice this for a day or so. The power button would do nothing. RAIDRAR shows the unit as blue and I cant get to setup. I...
Mar 19, 2013Guru - Experienced User
If you have a backup, then going to factory reset is reasonable. You could well end up there anyway.
You could try an OS reinstall first. It is a long shot, but on the other hand costs you nothing .
If you don't have a backup, try the boot option to skip the FS check.
